Hi everybody!
New to me Rainier owner here. I have searched the forums, and I think I have an idea, but I would like a little verification.
My front wipers will only run at fast speed, all other switch positions return the wipers to rest. Also no washer action.
I have verified that the washer pump works. If I leave the switch on one of the other speeds, occasionally they will turn on then quit shortly thereafter. I thought about the pulse board circuit, or the multifunction switch{MFS}, but after reading posts, and studying wiring diagrams, I found that there are two rotary contact switches in the MFS that one failure could cause all my symptoms.
So. Is the MFS my most likely culprit?
Thanks!
TJ - Panama RED
2005 BuicK Ranier CXL AWD 4.2L 150K miles approx.
Thanks!
TJ - Panama RED
