The money light is on and it's a U0632, lost comms with left cooling fan (yeah, the fans are on the network!). Tried to disconnect the fan to do some diagnosing but I just wound up finding a feral cat under the hood. As best as I can diagnose, I figure it's the module in the fan that's borked as it also threw a U1345, LIN Bus communication fail but after I pulled the fan's fuse and reinstalling it, that error disappeared, leaving me with just the fan error. The only way I can disconnect the fan is to remove them so I may just shotgun it if I have to do that.
I was eventually able to disconnect the fan and check the voltage, ground and the LIN Bus wire for data with a small scope I bought on Amazon. All were good except the data line showed a different wave form than what I have seen on the Net.
Normal:
Mine:
Normal:
Mine:
. Scan shows the same codes it had before (U0632 (fan 1 communication loss) and U1345 (LIN Bus 1 communication error). When I clear the codes, only U0632 comes back up. A bit of research and possibly something else on the LIN Bus is putting garbage on the network or it's a wiring issue even though I checked the data line with a scope. I'll have to check again by unplugging different modules on the network and see if the network traffic changes or that code goes away. Supposedly the active grille shutters are usually a suspect.
