- Dec 3, 2011
- 367
Not sure which the cause of an issue is more likely the case, so figured to check here and then ask for opinions..
2004 Envoy XL
175k on odometer
Recommended service done since 36k
Drive 80 miles round trip each day for work mostly highway
Few weeks ago I noticed the gas gauge was not moving below 1/4 even when park on hills. Good thing I always reset the trip as some quick math told me I was low. So I stopped for gas and sure enough she took 23.5 gals.
Gauge seemed to work / reset normally when I start the truck as in it would go from far left when off, to full right, to rest at half tank. A few days like this not going below 1/4, then I noticed while driving, the needle slowly went all the way to empty, then all the way to full.
It stayed that way for a few days. Then I noticed a few days ago it would slowly move between full and 3/4. It is back to staying at full. Yet this entire time it still does the normal full sweep when I start the truck?
So .. Bad float / sender unit or bad gauge temper motor?. (on a side note .. The dash light that illuminates the right half of the speedometer is out)
Any thoughts would be appriciated
2004 Envoy XL
175k on odometer
