I am having an issue that I have not been able to find any information on. I just bought my second Envoy XUV. This one the roof and back window both work but in reverse. Window up goes down, Roof close goes open. The problem this is causing is that when the window is up, it thinks it is down. So the roof will only operate when the window is up. That could cause an issue. Same with the tailgate, it only drops if the window is up. I'm especially confused that the roof is also going backwards (close is open, open is close) There must be something that flips the computer into running these both backwards. Please help. I do have an autel scanner and can force them all to operate. all motors run good.
