I just had an issue of the engine running rough at idle, and then finally threw a P0017 code. Turns out the VVT Solenoid was stuck. Replacing that fixed the problem, but now the TC will not lock at steady speeds.
I'm due for a trans fluid and filter change, but is there something else I can test when I'm in there? Possibly the TCC PWM solenoid?
