Envoy Rear Upper Control Arm Bracket Repair
Camdo
98
2005 GMC Envoy SLT 4.2L Located in Boston area,
I was hearing some knocking and assumed it was the spare tire. Upon investigation I discovered the frame was severely rotted around the rear axle upper control arm brackets on the left and right sides. The spare tire was loose too!
An internet search on Ebay and Amazon came up with many ready made brackets of varying cost. I chose the least expensive.
Here it is. Nicely cut and fit up well, but it was painted and the paint was a pain to get a weld arc going.
I used 1/8 inch 6011 weld rods which penetrate the paint well. As can be seen, I am not a welder but every 5 years or so I weld something. The small bracket that holds the brake line did not come with the bracket kit so I made that myself. Use 1/8 x 1.00 inch steel bar and bend it in a vise around a piece of 1.00 inch bar stock to make the U shape. Drill a hole in the center .50 from the edge so the lip of the brake line fitting will rest on the edge and not rotate. You will need a 6mm retainer nut to complete the job (not shown).
Welding on the old nut was problematic as the thin retaining stock melted quicker than the weld to the bracket. Ugly but it holds. If I had to do this again I would pay a little more and get a bracket that was premade with a nut welded in place. That would save hours of work.
A small right angle grinder prepped the rotten frame. Luckily there was some metal still intact. Unfortunately, I sliced the steel brake line which made a mess and a ton of work to fix. As always, it is best to look at what you are doing and not act blindly.
The bracket welded in nicely. I used the upper control arm to hold the bracket in place while welding. The 6011 welds are ugly but strong. Only a few edges were accessible for welding. After cooling, I painted the bolt with never seize because if it were to seize to the nut, it would take a lot of torching to remove the control arm.
The weld that matters is on the rear edge as that is aligned with the control arm. There is no up or down reaction force because the control arm is pivoted on both ends. A little weld to avoid flexing is all that is required, but I welded as much as I could get access to, anyway.
15 hours total labor. about 5+ hours per side, and 5 hours to fix the cut brake line. Spread out over 3 days
$45 for the brackets,
$20 for a pack of 6mm retainer nuts and some 6mm x 40mm long stainless steel hex bolts.
$30 for 10 Lb. 6011 weld rods 2 lb. actually used
$20 for misc. brake line fittings.
$20 1 Quart brake line fluid
$135 total
I wonder if those brackets were prepped with weld-through primer?
Definitely not weld thru primer. I tried wire brushing a few joints with a power brush but that was a lot of work with poor results. It was tough paint and It took many hard strikes to get the arc going., not to mention the ground clamp issues. 6011's go thru paint once you get the arc. They also work good over rusted metal.
I would avoid the brackets I purchased. I thought it would be an advantage to weld the plates on the frame so as to get access to the forward joints. But it turned out there was no access anyway . The frame was flat in the bracket area, so fit up was not required. It would save a lot of work to buy brackets already made up left and right with the nut welded on.
I just did this repair myself with a little flux core welder my wife bought me for Christmas last year. Worked a treat....
BUT.... I used prewelded brackets.... and could not use the prewelded brake line mounts. The angle I was forced to weld the brackets on tilts the mounts at an angle that I simply cannot bend the existing brake lines to. I have yet to implement a fix, but it will involve slicing about 3/4" of material out of each brake line mount, bending what's left back together, and rewelding it. Regardless, my Bravada passed state inspection on the first try for the first time in years(even with the brake line mounts not being right). Now, I did cheat when removing the old mounts and left the upper, double thickness, plate in place and removing everything else, including the captured nut. I ended up even having to cut out the material around the hole the captured nut keeper goes in to as the prewelded brackets I bought already had nuts welded in place. So, I zipped a weld all around the new brackets which had the additional benefit of closing the rusted out hole that was hidden behind the upper arm when it was installed. In short, I'm not sure that prewelded brackets were necessarily a better choice. They probably did save me time, but ended up creating a (small) new problem. Probably more a matter of preference...
The un-welded brackets I used did not have any bracket or provision for the brake line mount. I had to make my own and wing it as to fab and dimensions which added a lot of time to the job. Believe me, you made the right choice using pre-made brackets with the nut already welded on.
flames5000
