- Aug 25, 2012
- 955
Hi all! It's been awhile since I posted a new topic. I wanted to see if anyone could help provide some insight on flushing the power steering fluid on the trailvoy. Mine is a bit dirty but doesn't have any whine on the pump but as a good measure I want to drain the fluid and flush it totally out with new. I was thinking to do a makeshift of may03's video with flushing the transmission fluid out where he pulled the transmission line that feeds fluid into the radiator to dump it into a bucket and keep pouring fresh fluid into the transmission until it comes out the same color as going in.
I was thinking to remove the rubber hose that is the hose returning to the power steering pump and is coming off the power steering cooler to have that drain out into a container while having the engine running and then keep pouring in PS fluid to the reservoir until it comes out nice and clean on the other end. Does anyone see any problems with doing this? I figured that since I am simply opening up the low pressure/return side of the PS system that it would not have adverse affects on my steering for having air into the system. I do have a vacuum pump and can buy an attachment to insert into the top of the PS pump reservoir to suck out any air into the system if it is necessary. I just want to ask before I run the risk of having a big mess on my hands or worse make the system get air into it and wreck my rack and pump.
