Envoy ebrake actuator
glarc
1
On my 02 Envoy the right side actuator will not return disengaging that ebrake. Is there any maintenance or adjustment possible?
Plenty of levers and a cable that could use lube. May also have broken bits inside the rotor top hat where the shoes are. Pull the tire and rotor and look.
May 5, 2014
19
Had a car & truck where the ebrake wouldn't release. Found both times the trouble was the cable sheath was rubbing on the frame. Once the sheath wore through the cable was next & the individual wires would break and bend around - locking the ebrake.
Easiest fix - replace the cable.
Firebaugh86
