Engine swap - remove tranny or leave it?
silver007
16
GA
What's ya'lls opinion? I've got the trans separated but I've got to bolt it back up and turn the truck around in my garage. I'm thinking more about what's easiest when hooking it all back up. Should I remove the trans with the engine so I can bolt it to the new engine before I put it back in?
'07 4.2 2wd
Maverick6587
730
Sterling Heights, Michigan
Pulling the body off would be the easiest. If you have or can borrow a hoist, pulleys, or a bunch of dudes to lift it off and up high enough.
Otherwise, just remove the hood and intake and intake manifold and it shouldn't be too bad removing it from the engine bay.
Kelly@PCMofNC
187
Are you pulling the powertrain from the top or did you pull the body off of the truck?
wentzben
