Unable to get the engine going. This morning sounded like it turned over for a moment, but I could have been imagining things with a late night. Tried jumper cables, then a trickle charger with no results. Tested all the fuses, all good.
Most recently I installed LED ribbon under dash, rear seats, and under each door. Spliced off gray/black dome wire, grounded to door, all working fine. I did cross pos and neg wires during install, blew fuse #4 in BCM which I replaced and domes worked fine. All connections heat shrunk/taped.
Battery is about 8 months old.
Video shows key insert and start attempt at the same time the hazards going strange speed with dim illumination on dash. Not sure if sound effects and gauge jumping is standard after ignition turned off, one of those things I never paid attention to before.
Any thoughts or wisdom is much appreciated. Next step is trying a new battery?
[video=youtube_share;Wl20hbCulNo]http://youtu.be/Wl20hbCulNo[/video]
