Engine mount heat shield
NJTB
612
Flemington, NJ
All
I'm hoping someone can help me out. In a week or two, new motor mounts are going in the TB, and am searching for a motor mount heat shield. Several sites have it as a discontinued number (15875691), and the ones that don't (GM parts giant), canceled the order.
There's also a superceded number I've tried, no luck.
Anyone have any ideas?
10,685
Did your current one get torn off at some point? If not, just re-use it. :twocents:
7,732
If you are unable to locate the OEM Heat Shields….DEI makes a High Temp Adhesive Heat Shield Protective Material that can be securely Custom Crafted or Creatively Shaped over and around those “Rubber Biscuits”, Available for $10.00 on eBay:
NJTB
612
Flemington, NJ
Blckshdw.
No it didn't get torn off, but it's rusty and I don't expect it to survive the motor mount change. My thinking is if it was there originally, it must be doing some good, so I tried to find one to replace it.
MRRSM
Looks like that's going to be my fallback, better than nothing.
Thanks all.
MEHMET ONUR
