Hey guys. I just finished doing a total engine overhaul on my 2003 Trailblazer EXT, including new timing kit, water pump, serpentine belt, thermostat, fan clutch, ignition switch, and muffler/resonator (but no new catalytic converter). Took it for a test drive, and it was running good, but after driving it for approximately 12 miles, the engine started knocking, so I parked it overnight. The next morning, I checked the oil and started it. It was running very RICH, even blowing soot from the exhaust. Code 0340 (over advance timing). I tested the camshaft position sensor, and it was in spec. Reset the codes, and started the engine again and got a check engine light. OBD code now showing P0014. I pulled the camshaft actuator. The screens were intact and still clean. I cleaned it anyway, and back probed the wiring to test the signal. Checked out good, although the connector end spun on the solenoid. I disconnected the battery to reset codes, and reconnected. Started the engine again and still got excessive fuel mix from exhaust (moisture with black soot), and engine knock. CEL on, but showing NO CODES.
Although the sensor and solenoid tested good, I replaced both of them. The new fan clutch runs 100% of the time, and has since I installed the new one. The engine knock is still pretty constant, although it goes away, shortly, at times while at idle, and I'm still getting soot from the exhaust.
Any ideas on where to go next? Is there a way to test the Dephi camshaft actuator? Could it be a bad oil pressure sensor, or a bad crankshaft position sensor?
Thank you!
Thank you!
