Huh? I see the intermediate shaft hole cast into it, and thought they were all 4WD capable. What are you seeing that limits it to 2WD?CaptainXL said:That's a 2WD engine oil pan on there.
Grimor said:well, I got a 2007 (I was told it was a 2006 when I bought it but whatever)out of a junk yard ins wreck that supposedly only had 80k miles on it. It looks like it was hit pretty hard.
Not bad,using my intake anyway
Not sure what mounts to this part that is broken off. I thought it might be the motor mount but that's a bolt on. Should I be worried about it?
I plan on doing new plugs and CPS, anything else I should replace and are there some gaskets that need replaced when swapping stuff over? I've searched around some but most the gasket/seal kits I found were for engine rebuilds I think.
BRomanJr said:IMHO, YES, Looks like a broken motor mount bracket to me, cast into the block, not much hope that will be repairable.
The_Roadie said:Huh? I see the intermediate shaft hole cast into it, and thought they were all 4WD capable. What are you seeing that limits it to 2WD?
jimmyjam said:pretty sure the motor mount brackets bolt to the block, and higher up than that.
CaptainXL said:Why doesn't someone just look in their engine bay and check to see if that is the mount. I think it is. The other side of the mount bracket bolts to the frame, not the engine. The engine just simply rests on top of the mount.
BRomanJr said:Actually glad for the OP, wonder what that is for.
jimmyjam said:While I'm at it, there is no such thing as a 2wd oil pan.
jimmyjam said:There is no plug there. You are seeing light shining through the axle hole.
jimmyjam said:Seems like you guys are celebrating 4/20 a few days early
the v8s have a similar holes on the bottom of the blockBRomanJr said:wonder what that is for.
I'd port and polish the heads while they are off and Kooks makes headers.Grimor said:thanks for all the help guys, I won't worry about that broke piece then. And the consensus is that there is no such thing as a 2WD oil pan? lol
Is there any bolt on stuff (maybe a different oil pan, headers, etc) that I might want to look at while it's out?
And gasket wise, any suggestions on what I'll need? I'm not sure if any of the gaskets on this are reusable or if any bolts need replaced as well.
I didn't think kooks made headers for the 06Pittdawg said:I'd port and polish the heads while they are off and Kooks makes headers.
I could pull the head on the bad engine and see if it has any problems, that'd give me some time to get them back before the engine needs to go in. take off, leave on, I just want to make sure I do whatever I can to make sure this engine is going to run when it's in. I know pulling the head risks broken bolts, which would create problems. the good thing would be I can take the entire engine into a machine shop this way lol.jimmyjam said:do you really want to take the head off? make sure you are handy with a bolt extractor... if you do take them off, i'd take them to a shop to get a valve job done on them
I'm pretty sure it's just a different connector piece for 06-09 and that Kooks will provide it if requested.Grimor said:I didn't think kooks made headers for the 06
I think I need some better vice grips, the ones I have just won't bite enough and stay gripped to turn it.limequat said:I think keep at it with the vice grips. Have you tried soaking it in liquid wrench yet?
A few taps with the sledge to try to break it free?
I've tried welding nuts on, almost never works for me.
Unless someone just wanted something to practice on, I doubt there is much good left on that head unless you take it completely down and start over.limequat said:MY GOD. That is the nastiest 4200 I've seen, and I've seen some with holes in the block before.
However, that head might be worth saving for a port/polish project. What do the cam journals look like?
