- Aug 26, 2012
- 1,079
thought it might be useful and helpful to start a discussion on how electrical systems work.
point here is to further understanding and have a helpful discussion.
the generator includes an alternator, and internal regulator, which controls the field current in response to it's design and controls, to attain a specific voltage.
older model years have an internal temperature compensated regulator, which changes the voltage according to temperature. when it is wicked cold. (ten below for example) it operates as high as 15 volts.
in some of the newer years, GM added logic and elements to the internal regulator which lets the voltage be set according to a pulse width modulated signal.
it still is a voltage regulated generator. the regulator will increase the field current which makes a magnetic field that the pulley turns to generate the output current, rotating fields generate AC current, so the included diodes rectify to keep things flowing in one direction.
