Here we go, must be a newer-year to do a P0411. Incorrect flow detected is what that's saying. If the valve were closed, it would be impossible to have any flow in theory....
Confusingly, the 2008 manual has the purple lead from "air solenoid relay" running to "Secondary Air Injection Pump Relay" according to the wiring schematics.
Alright, what color are those wires? Black, Purple, Dark-Blue/White, Brown/White, and Yellow, yes? Purple is the + and Black is the ground for the solenoid. The two white-striped are the inputs, and the yellow the output of, a sensor that appears to go two-way, which my guess would be that this could be the sensor determining airflow. Go one way, it says it's all good. Go the other way, it'll P0411. Stay centered, it'll assume either the valve failed to operate or the pump failed to activate. How it looks to me, anyway, with one being a positive-voltage reference and the other being a low reference to determine exact positioning, like in the TAC and the APPS.
