The family's TB has recently started making a droning noise from the front end which seems to be getting gradually worse. It sounds very much like a hub bearing may be going out, but turning left and right doesn't make the noise either go away or get louder. The noise is probably not the engine as it is constant with vehicle speed. The noise does not change when the tranny upshifts into a higher gear and the revs fall accordingly.
Ironically, the noise started soon after I changed one of the front hub bearings because the ABS wire got severed (not a removable ABS sender; hard-wired into the hub) and I wanted ABS back for my wife with winter on the way..!! Not being a big believer in coincidence, I do not rule out the fact that the noise could be the new hub bearing, but more likely that the other side is just going out at the same time.
Any other components that I could / should check that would make noise in line with vehicle speed..?? I want to replace the half shafts this spring / summer, but I would imagine they would make more of a clicking noise if they truly worn out. They have flung grease but the rubber boots are intact.
T.I.A.
Dave.
T.I.A.
Dave.
