DRL Disable with Auto Headlights
This write up will be to disable the DRL function. This method uses a relay spliced in at the bcm and will disable the DRL, along with keeping the auto headlight function, but It will also disable the low beam's night time perimeter lighting function while remote lock/unlocking. Disabling the DRL is beneficial when installing HID low beams as the pwm signal of the DRL decreases the life of the ballasts.
Summary: Disabling DRL while retaining Auto Headlight Function
Difficulty: Easy to Moderate
Estimated Time: 30-45 min
Total Cost: $10-$20
Required tools:
Wire stripper/cutter
Crimper
2x red butt connectors
2x red scotch lock connectors
1x 4 pin relay, preferably with relay socket to make installation cleaner
4x Random lengths of wire with a female spade connector on one end of each wire if not using a relay socket
Note: Being we are going to be working on the bcm connectors, if you are not comfortable with electrical wiring then find someone who is comfortable doing it. The author takes no responsibility if you mess up the wiring, or worse yet the bcm. Also as like any electrical modifications, DISCONNECT battery before preforming any work on the electrical system.
We will be using this diagram to install the relay into the wires at the BCM.
Also the relay socket I am using has the wires color matched to the BCM.
5. Next we will find the white wire in Pin B6 of the gray plug. Follow the wire back about 3-4 inches away from the plug and use the scotch lock to connect the wire to pin #86 of the relay
6. Finally, on the tan plug find the pink wire in pin E7. Follow that wire back about 3-4 inches from the plug and use the scotch lock to connect the remaining wire to pin #85 of the relay. When done it should look similar to this.Once all connections are made, plug the relay into the socket, connect the battery and make sure the DRL is disabled. Once everything checks out, find a secure place for the relay, install the fuse box cover, and replace the rear seat.
Total Cost: $10-$20
Required tools:
Crimper
1. First we have to access the BCM. Short wheelbase models will need to pull up on the rear driver side seat to expose the fuse box cover, and then remove the cover off the fuse box and BCM. Long wheelbase models will need to remove the driver side second row seat to gain enough access to the BCM, once the seat is removed you will be able to take the cover off of the fuse box to access the BCM.
2. Once we have access to the BCM its time to disconnect both plugs on the side of the BCM (a gray plug, and a tan plug). From here you will need to remove some of the tape around the wires to give you enough room to cut and tap into the wires we need to.
3. Find the pink/white wire in pin A5 of the gray plug. Follow the wire back about 3-4 inches and CUT then strip the ends of each of the wires.
4. Next we will use a butt connectors to connect the pink/white wire from the BCM to pin #30 of the relay, and the pink/white wire that goes into the wire harness to pin #87 of the relay.
