Drivers side ceiling mount speakers?
TonyT
108
I have my amateur radio license and I like listening to truckers occasionally while driving for road reports. So I'm considering installing several speakers on the roof behind the drivers seat. I understand there is almost certainly a nice chunk of sheet metal between the B pillars to screw the mount onto. Is this correct? Any comments or suggestions?
I'm also going to be drilling several holes in the roof sheet metal to mount antennas using NMO mounts. Seems to me both projects will require lowering the interior ceiling so I should do both at the same time.
(I'm also going to be going overboard and installing several hood lip mount antennas too.)
Mark20
1,630
You need to make sure the speakers won't be a hazard in a crash. A friend got clipped by a drunk at an intersection. While that in itself didn't inflict any injury the rapid spinning of his car caused his head to slam into the A-pillar resulting in a bad concussion.
TonyT
108
Hmm, good point. Right behind the head would be fine as the headrest should take care of that. But the other ones would need to be out of the way and not be a hindrance to the rear seat psgr. Not that I have psgrs very often. Not a lot of leg room either back there.
Mark20
1,630
I have a Radio Shack 4 inch (?) speaker tucked low in the passenger side of the center console. It is muffled sometimes. I've been thinking of relocating it.
TonyT
108
These are 2" speakers I picked up on eBay for darned cheap. But they're going to have to be close to my ears so I can get decent sound.
That said there was an interesting thread on putting in an aux jack on the XM receiver cabling if my radio has such. I'll have to RTFM the manual. But I still like the idea of audio being on the left, centre and right so I can figure out which is which.
NighTblazer
71
what about putting them in the b-pillar? If you don't use on* you could possibly replace the the on* speaker or mount them similarly below it.
TonyT
108
Mounting on the B pillar is an idea for one of them. I'll have to take another look tomorrow to ensure there is no possible way for my body to hit it though.
I didn't realize that on* had a speaker there. I never plan on using it so excellent idea. Thanks. I have one 2" speaker for sale now. :smile:
Porkins
6,960
I've seen people mount them in a headliner, if you wanna cut you headliner.
TonyT
108
I don't understand what you mean. Do you cut holes in the headliner the same shape as your bracket to mount the bracket directly against the sheet metal?
There is no speaker or microphone in the b-pillar, for OnStar or any other option. If you see a grille near the driver's left ear, that's a tiny squirrel cage fan that draws in cabin air to a temperature sensor used by the high-end digital HVAC control system. Lots of folks guess it's a microphone, but that's in the overhead console so the OnStar and speakerphone system can pick up the voices from all occupants. OnStar and the speakerphone system use the normal entertainment system speakers.
Porkins
6,960
This, I've seen it done on a few SUVs. Thought it was a cool idea.
TonyT
108
Now that is neat and tidy and looks a lot better than speakers with mounts, etc.
Thanks for the idea.
Firebaugh86
