the roadie said:That's the normal behavior when the AC compressor comes on and steals a few HP. Pull the AC relay from the front fuse block if you want to prove it. How many vehicles have you owned before now?
RayVoy said:Are you feeling this "drag" when the fan (blower) speed is changed?
RayVoy said:Ok, that's probably not the compressor.
The blower motor will run faster (more voltage will be across the motor, instead of the voltage divider resistors); but the additional load on the alternator should not be high enough to load the engine.........hmmm, but maybe it is.
As I'm typing, I'm thinking that between the alt and the battery, the pair should be able to run the blower without any problem, but maybe one of the 3 is defective.
Perhaps the blower motor is not turning freely and causing a larger load, not high enough (yet) to blow the fuse, but enough to overload the alt.
Perhaps the alt is having problems when a demand is applied and overloading the engine.
Perhaps the battery is not provide the storage required and overloading the alt.
the roadie said:The blower fuse is 30A. At 14 V, that's only 420 Watts. Under 2/3 of a horsepower additional load on the alternator.
If losing 2/3 HP is a noticeable drag I'd be shocked.
I bet it's some psychological effect of more wind blowing in your face.![]()
deekster_caddy said:The more demand you put on your A/C, the more load on the engine. You have 3 hp drains when you crank the A/C to max - the blower (roadie already discussed), the A/C compressor (good for a few hp loss) and the engine fan, cranked to max because you are demanding the most from your A/C (good for a whole bunch more hp).
The engine fan is probably having the biggest effect.
Is there a way to force the A/C compressor off? If so try it then repeat with the fan on high vent instead of high with A/C. I have to ask the last question b/c I'm not a TB driver.
Ghost said:If im doing 65-75MPH ± and turn on the heat full blast or air i can feel drag on the front end ?
Ghost said:Bump.
When heater or cold air is turned on at 5 its hard to keep the truck driving straight on the freeway at 70+ MPH. I know it's not psychological because i had a buddy of mine complain while he test drove it and my gf also noticed it
the roadie said:And the problem doesn't happen at blower speed 3 or 4? There's less than 10A difference between these speeds and 5.
Can you see the voltmeter droop on the dash when you do this?
What happens if all the windows are up, and you press TWO of the window switches to try to raise the windows? This adds 20-30 Amps to the load on the engine, which should definitely droop the voltmeter.
EDIT: How about adding the electrical load of the rear window defogger? What happens then?
Ghost said:No rear window defogger??? Sucks. When pressing two switches everything dims out like the truck is going to stall. If im sitting at a light at night and press two windows switches up even the windows are up rpms drop to almost 500±.
On free way at 70mph and.doing thw same with the switches feels like truck is going to stall lol.
And does the power steering change behavior?Ghost said:When pressing two switches everything dims out like the truck is going to stall. If im sitting at a light at night and press two windows switches up even the windows are up rpms drop to almost 500±.
the roadie said:And does the power steering change behavior?
As suggested, load test the alternator and the battery, and I think you said you had a clean throttle body, then suspect a dirty CPAS for not being able to let the engine hold a solid idle.
Ghost said:where is the serpatine belt ?
C-ya said:This is the drive belt on the front of the engine that drives the alternator, water pump/fan, a/c compressor. There will be a tensioner pulley that is spring-loaded. You'll need a ratchet or breaker bar to release the tension to get the belt off.
DFWWIZ said:That's bizarre! I think you have a "ghost" riding with you robbing you of power.![]()
CaptainXL said:Seems like a bad connection or weak output voltage regulator. Remove the alternator and get it tested. A new battery would only serve as a bandage due to its higher reserve capacity when new. And I think AM noise is related to a faulty bridge rectifier.
Ghost said:If its any help i never never use my a/c. I do use the blower button to get more air but that's it. I guess i need an E fan. I could tottaly see the oem fan in the front of the engine causing massive hp loss & drag. Ill try what u said little bit later today its still rainy outside
Ghost said:HP isn't my issue its trying to keep the truck driving straight while doing 65-75mph on the highway.
CaptainXL said:That's pretty vague. I would suggest a good alignment and suspension inspection + brake inspection if your vehicle is wandering or pulling on the highway.
Power steering and belt do not correlate well with your description. With the rate that the tires spin on the highway you could have zero power assistance and should still be able to steer fine.
oh and the exhaust was a little loose
