meerschm
- Joined
- Aug 26, 2012
- Posts
- 1,079
well, the drivers side rear window is acting flaky,
skips and then does not quite close all the way. looks like it is on the agenda for tomorrow, in between setting out lignts.
any hints on how to get the inside door panel off?
or what to be careful of with the window?
Thanks
Thanks
) The perimeter of the door is held on by plastic push pins. Wedge a screw driver or trim tool between the metal and plastic, and pop them all loose. Should take you about 5 minutes max.
