I've repaired the cold solder in my EBCM once on my Rainier. The fix worked for a couple months but the truck is back to throwing the ABS/BCM error lights and turning off my antilock brakes. My question is how does this effect traction control? Would assume that when the system detects an error with my brake control unit, it can't effectively work traction control given it will be locking up the brakes, right? Should I be hitting the TCS OFF button every time I drive until I get the brake computer replaced?
