6716
- Joined
- Jul 24, 2012
- Posts
- 836
Many thanks to Mooseman for the manuals (I had to laugh, though, that the "overview" section for how the HVAC system works was at the END of 450-odd pages of documentation).
So here's where I'm going with this:
I have a recent issue where, after a few hours of continuous operation, the A/C is still "cold" but not much air comes out of the vents. Given that the problem resolves itself overnight, the blower motor and resistor pack check out, the compressor is running, the clutch doesn't seem to be slipping, the hard lines and accumulator are cold, it is possible that the evaporator is icing over and blocking airflow.
What I'm thinking is that the compressor is not shutting off at any point (since I stood and watched it for 15 minutes last night (the neighbors already think I'm a nut)). The manual suggests that there are numerous (12, specifically) conditions which will cause the A/C compressor to shut down.
So if the compressor is still running
1. Ambient air temp is > 35*F
2. A/C compressor temperature switch contacts are closed
3. Throttle position is < 100%
4. A/C low pressure switch is closed
5. A/C high side pressure is not higher than it should be
6. A/C low side pressure is not lower than it should be
7. Engine coolant temperature is lower than 253*
8. Engine speed is less than 5500 RPM
9. Transmission is not shifting
10.PCM does not detect excessive torque load
11.PCM does not detect insufficient idle quality
12.PCM does not detect a hard launch condition
Since the compressor is still running, I think I would have to rule out everything BUT either #2 or #4 as the source of the lack of shut-down on the compressor.
Now, here is some FURTHER INFORMATION:
Last summer (maybe 13 months or so ago) my A/C was blowing hot and I took it in to Firestone (I get Destination A/Ts there, the last set lasted 70K, and with the full warranty package I get lifetime free rotation ... so I go in for oil changes and free rotation every three months) and asked for an A/C check. They said everything checked out, but I was low on refrigerant, so they topped it up. $50 for the check, $8 for the refrigerant, it blew cold, and I was happy. For four months.
Four months got me past my next oil change, and into September, so when it quit I just toughed it out since winter was coming anyway.
This May when it got hot again and I was due for an oil change I brought it back to Firestone and had them re-check it (which they did at no charge) and they still couldn't find a leak, but it was definitely low, so they topped it off (again, at no charge). I pressed the guy at the counter for an answer, and his only thought was that there was a leak, but it was under the dash where they couldn't see the dye.
So here I am today ... it's still making cold air, I'm due for an oil change in a week, if I have a four-month slow leak under the dash the issue won't appear for another month ...
and I have to wonder (here's the bonus question) ...
Are the possible system leak and the lack of compressor shut-down related? Or no, and each could and should be approached and resolved independently?
