07 saab 97x 5.3i
Can’t hold water pump from turning this water pump is smooth on front there aren’t 4 bolts on the water pump pulley. there aren't any holes in the pulley either.
Here is the tools I got from advance auto no one there knew how to use these tools.
The big wrench isn’t an exact fit on the clutch fan nut there’s a possiabilty of rounding it off if it’s on real tight.
I'm starting to think I have the wrong tool if I remember correctly it's called a spanner wrench which I've never used either.
Please need advice to lock down waterpump pulley.thanks for any advice.
additionalley are the 6 cylinders fan the same as the L33 v8 5.3litre engines fan?
According to rockauto they are the same part#.as the fan clutch.
this fan is kindof pricie to replace. I may be able to recycle from the junkyard.
Please recommend a decent rad.& Clutch fan including links would be good.
the good news is shes out out the mud
