I've got lots of questions about my differentials. First, the basics:
From what I read here, the SS has a 9.5" rear, the EXT & 5.3 have an 8.6" rear, and the i6's have a 8" rear. Is all of that correct? Do they all share the same front end? If so, what size is that? Also, for comparison, anyone know what a 1500 and 2500 pickup has for front and rear diffs? Are there any other specs i'd need (like bolt count or spline count) to pick out one that works with my truck?
All my old ZR2 Blazers had G80s in the rear, and it was very nice. I had 4 wheel drive but I rarely used it. With my trailblazer (open front and rear), I'm constantly using 4 wheel drive in the winter. I originally wanted a G80 in this truck, but my mechanic has suggested a Truetrac would be a better fit for me. While I never had any problems with any of my G80s, even when they were old.... a 5.3 is putting a lot more torque into it than a 4.3 can. So I have some Truetrac specific questions...
First, do they make them for our fronts, whatever those are? Front and rear traction differentials would make my truck a traction beast, that would be nice. Mostly for the snow, but sometimes I launch my boat on a beach, or I could potentially have to get into some mud to rescue the boat if things ever got sketchy. Or a million other unforeseen reasons* why more traction would be good. Upgrading rear only is my basic plan, and if I can do both without breaking the bank, I'd like to.
Leading to another important question, it sounds like a truetrac shouldn't affect steering at all in the front? I was originally told it might understeer a bit, but from how I understand they work, it seems like it shouldn't? Other than when I'm sliding in the snow and have all four wheels slipping, but when that happens, a little under or oversteer is not important.
I'm also not 100% clear on when a truetrac will lock. I read that if one wheel is in the air, it might not engage causing that wheel to spin. But if you tap the brake, that will get it to 'engage'. This will rarely if ever be an issue for me. But if it were, wouldn't the traction control automatically his the bakes of the free spinning wheel causing this to engage? I know stability control turns off in 4 LO, does traction turn off in 4 HI? And if I was in 2 HI, shouldn't it definitely do this?
Also, related to this. I'd be concerned about one tire spinning on ice preventing the system from engaging. This is the real world situation I'm in regularly in the Winter. Is it sensitive enough that ice/snow slip will prevent it engaging? Or is that a case where I may have to tap the brake (or let traction control tap the brake) to get going?
Are there any other good options I should consider for rear end traction enhancement? Like a Torsen? I have no interest in a full locker. I'd prefer something fully automatic for the rear, though I'd consider an electric locker in the front if that were the only option. Although how would a TB handle in the snow with the front axle fully locked, and the rear running a truetrac? While writing this thread, I googled up the Torsen diff and watched a 'how it works' video, it actually sounds like it's better than a Truetrac?
*Here's another unforeseen reason. One night at like 3am, I was driving home the long way from my GF's house and I went by what looked like a night work crew doing work on a side road in Arlington. They threw down a lot of sand on the road like they had just paved a section. Well turns out it wasn't paving, something must have dumped some kind of oil or fluid on the road. When I got to the next traffic light, I hit the brakes and kept on going! Even further down the road, I get to a rotary and fish tail my truck like it's the middle of February. The roads were bone dry when this craziness happened! A few miles later everything had gone back to normal.
