Okay, I'm going to divert from the OP's question here a bit:
...and say that I absolutely hate dexcool!
In all three GM vehicles that I've owned since 1997, they've all had some sort of brown sludge-crap buildup in the radiators and it's very hard to completely remove!
I've never serviced the radiators prior to this problem. In my 1996 Camaro (which I no longer own), I bought it brand new and found the sludge one day when I was changing the oil. I looked at the fluid inside of my coolant bottle, and there was a bunch of brown, silicone-like sludge chunks foating around in the bottle. I removed the rad cap and found the same thing! The car had somewhere around 15k on the odometer, so I took it to two separate GM dealerships for their analysis.
Both places said it was normal!
Since that time, I've bought and still own a 2006 Pontiac GTO (bought it new) and my current '03 Envoy. They too have the dexcool curse! Although, the coolant in both of them isn't
nearly as bad as what it was in my Camaro. My GTO currently has 14,762.8 miles on it and the Envoy has 122,629 miles.
I wish I knew what was causing this. Some people that I've talked to say that they've never had an issue like this and they love dexcool. While others have had the same experience as I have and they share my opinion. I've also read about a lawsuit filed against GM, but nothing ever came my way mentioning a recall.
When my Camaro reached 36k and the factory warranty was expired, I went and changed to the green coolant and never looked back. I had to flush and fill the radiator many of times to try and eliminate the sludge. I even went so far as to removing the thermostat, running the engine, then disconnecting the rad hoses and draining it from there. After I flushed about 4-5 times, I went with a new water pump, rad hoses, thermostat, then removed and cleaned my coolant overflow bottle. Yes, there were still bits 'n pieces floating around after all of that!
Sorry for the rant. I just wanted to offer my opinion of dex-crap.
