NEED HELP Creaking Sound from Steering Column
$ Khalid ! 9130
1,465
KSA
Hi everyone
I would normally go ahead and grease the steering column shaft. However this is a weird situation. If I drive normally and turn the steering wheel there is no sound whatsoever. However when I activate any turn signal immediately there is a creaking sound as soon as I even tilt the wheel by a small amount.
Any one had the same issue and what would be a suitable fix for this
Thanks
07TrailyLS
423
Toledo ohio
Take the black plastic off from around your
Wheel. Disconnect the ignition module wire in the process and you'll be able to see 2 torque screws top and bottom of the steering column tighten those and see if it fixes your situation
Reactions: $ Khalid ! 9130
10,681
If you don't see screws, then the plastic is snapped together.
07TrailyLS
423
Toledo ohio
Just remember to unscrew your ignition control module. There's a single torque screw holding it in place. Very small one at that
Firebaugh86
