Good Afternoon! I'm new to the forum and this is my first post on any bulletin board, so I hope I'm doing it correctly!?!
Purchased a used 2004 Trailblazer LS EXT with 4.2L I-6, for my son's first car. Engine was rebuilt 46,000 miles prior to purchase at GM dealer. Drove it home with no problems, no check engine lights, nothing! Ran for a week while he spent time giving it some much needed TLC. Went to start it to take it to the tire store and no start. It would crank and crank, but never start.
Did the following diagnostics:
Checked ignition switch, long story, but ultimately ended up replacing the switch. Unfortunately same issue, crank no start.
Checked fuses, I've read a few of the posts and have checked all the fuses mentioned, all are good.
Battery was tested ok, even swapped it out with the battery in my 2500 hd, both batteries worked in my 2500 HD.
checked compression on the first 2 cylinders from the front of the engine back, with the old garden hose technique. Don't have a compression tester.
Checked spark by removing plug and arcing to ground, found it worked the hard way, I was touching the frame, YUOSA!
Can smell fuel in the throttle body and noise coming from the fuel pump.
Tried starting fluid in the throttle body, nothing, not even a snort.
No codes in the computer, probably because I had the battery disconnected for about an hour.
I'm at a loss, not sure where or what I should do next? Any HELP would be appreciated!
Thanks in advance!
Thanks in advance!
