- Dec 3, 2011
- 369
Hello group. Having a weird crank no start issue with my 05 SWB TB LT. Daily driver Some history below. ...
* Bought it in 2015 with 85K on the odometer. Now at 238K.
*Always used mobile 1 oil and filter.
* Would probably be at 300K miles if not for pandemic lock down
* Did maintainence when needed if not before.
* Fluids changed on recommendations if not before
* 100K and 200K tuned ups with plugs and coil packs
* Replaced Thorttle body assembly about 3k miles ago
* New fuel pump assembly installed about 6 weeks ago.
No issues starting until now. Rained the past few days off and on. Not heavy but consistant and steady. Went to start the other day and it did not start on first two cranks, it sounded like it wanted to start, but only did on third try. Idled a bit rough at first but then calmed down. I let it idle for a few minutes. Check engine light on yet ran fine rest of day. Pulled codes when i got home and there was P2135 : P2101 : P1516. Cleared codes and ran fine rest of day. That was Friday. Still more rain. Went to run it early evening yesterday (Sat) and same thing, this time it would not start at all even after 5 attempts. Can hear the fuel pump priming when key is turned. Any thoughts on what it could be or what to look for ?
