I would normally do all of my troubleshooting first but, my vehicle is stuck at the store right now. So, I just want to make sure that I have all of the troubleshooting steps I need to run in order and I'm not missing anything big.
I was at the store last night and got into the 97x to start it and everything seemed fine. As I was backing out of the parking spot, I put it into drive and made it about 20 feet before the engine just stopped running. I coasted into another parking spot and continued to try to start it for about 5 minutes and it finally started again. I made it probably 100-200 ft. and the engine stopped running again.
I immediately assumed I was having the "Starts when cold and won't run when hot" issue. I kept trying to start it for about 15-20 minutes as I waited for my GF to arrive. No dice. I ran the scanner on it and it has the following Current and History codes.
Current Codes:
P0014 - Camshaft Position Sensor - Timing Over Advanced
U1000 - Class 2 Data Link Malfunction
The two below are active codes because I do not have my transfer case plugged in.
C0306 - Motor A/B Circuit Malfunction
C0327 - Encoder Circuit Malfunction
History Codes:
U1064 - Lost communication with Body Multiple Control System
U1160 - Lost Communication with Convenience Control System
I do have a Tech 2 but, I have only used it to replace a radio and run a case relearn. Am I correct in running a Class 2 Message Monitor check withing Diagnostic Circuit Check, to see which circuit is malfunctioning?
Checks I will be running tonight along with the Message Monitor Check.
1. Checking fuses
2. Looking at the wiring for the tailgate (Is it just the wires inside the rubber boot at the top of the tailgate or it is also the wiring inside the tailgate?)
3. Ignition Switch
a. There are two different types of ignition switch starters that I have found. Which one is the correct version,
- ACDelco D1426D GM Original Equipment Ignition Switch
- Standard Motor Products US-337L Ignition Starter Switch
b. This seems to be one of those parts that everyone just defaulted to "It's the same as a trailblazer." Maybe it
is? I think I'll just grab this from the junkyard to start with. They actually just got a 97x in the yard yesterday, so
hopefully I'm safe with that one.
Let me know if there's anything else I should be checking.
EDIT: I'll tow it home today if I have to. I just really didn't want to (if I don't have to) with my GF's 08' Escape.
Current Codes:
History Codes:
1. Checking fuses
3. Ignition Switch
