- Feb 26, 2015
- 148
I have a 2002 Chevy Trailblazer LTZ with the 4.2 I6. I have been have a slight problem when I come to a stop the oil pressure gauge starts dropping, and it says oil pressure low shut off engine. If I give it gas it goes away and pressure goes up. It doesn't do it every time, but occasionaly when I stop it does this. The engine sounds fine though. It has no ticking or abnormal sounds when it does this. I checked the oil, and it was in the good mark, but it has less than it did at the oil change. So I checked for a leak. I have been parking in old gravel parking spot that is grown up in grass. I put it on concrete, and it is leaking oil. There is a couple small spots right behind the passenger side wheel. It is hitting control arm, or frame and running down both side. I can't tell where it is coming from, but its right below like the 3rd cylinder on the passenger side of engine. Anyone know where that could be from. Also is that low oil pressure likely just a bad switch? Thanks for any help..
