- Apr 22, 2012
- 26
Hi everyone,
I've noticed a few issues lately and I think they might point to a faulty coolant temp sensor or possibly a thermostat. I've replaced the thermostat once, about a year and a half ago. I did not replace the temp sensor (had the wrong part, it turns out).
It's been super cold here lately, which could be part of the issue, but I doubt it. -18F this morning on the way to work.
I've noticed really crappy gas mileage the last few weeks, below 13 MPG. I've also noticed my temp needle likes to sit below the 210 mark normally, but will bounce around between just below and just above 210. I hooked up Torque through a bluetooth OBD scanner and am seeing coolant temps between 185-190F during normal driving. I'm thinking that's a little low. I do not have a check engine light or a pending code.
I just wanted to get some confirmation from better minds before I dive into a thermostat/temp sender replacement if it's not needed.
Let me know if there is any other info that could be useful.
Thanks everyone!
Thanks everyone!
