I'm having all these codes pop on up the truck will run if you shift it manually but seems like it's stuck in 3rd gear or second. I have changed both solenoids and did a fluid change on it and no change same codes. Tested fuse 47 and have power on both sides so I don't think it's the ignition switch. Just need some help knowing where to go to test so I can fix the problem
