Took my vehicle in to get code read at first when I turn on the fan motor switch, I get the ABS, BRAKE and 4WD lights come on. It cleared all lights off unless turn switch on, checked brakes and front wheel speed sensors, going to take a look at transfer case sensor and rear axle sensor also check wiring see if a connector is loose. Any help to clear this problem is appreciated. When code read was told had these codes in my history C0055, U1000, U1041, C0379. Cleaned the service on frame for the ground wire under the driver side door. Vehicle runs good
