Code 0306 with no driveability issues
Chilly
28
Idaho
My 2006 TB 6-cylinder has been throwing this code for awhile now, but it seems to run perfectly fine.
Should I start by replacing the ignition coil? Or should I just inspect the plug first to look for something abnormal, and/or swap the coil with #5 or 4?
Swap the coil with another, clear the codes and see if the problem moves with the coil or stays.
Reactions: djthumper
Chilly
28
Idaho
Thanks for the advice, guys. I'll do that and let you know how it turns out.
chirobo1
