NEED HELP Cluster , hvac steering wheel Controls
Dmartinez_ss
3
Modesto California
My 06 TBSS Cluster , hvac & steering wheel controls wont light up .
I swapped them over to my friends SS & they do light up there but not on mine anyone have idea what can cause this ?
Only lights that work are from the radio & door switches
Thank you
10,681
:tiphat: Welcome to the forum!
So your headlight control module, HVAC, rear wiper switch don't light up either? My first suspicion is that something shorted the illumination circuit and popped the fuse in the rear block, but I believe the door modules and radio use that circuit to light up as well when the parking lights come on.
Did you have any work/mods done to your truck just before this problem popped up? The more info you can share, the better advice we can give you.
Reactions: djthumper
And there's the manuals that have he schematics. Link in my signature.
Dmartinez_ss
3
Modesto California
I bought the truck like this. i thought it would of been a simple fix like a blown fuse but i checked mostly all of them & there good
14,950
That would have been some good information in the first post. Did you happen to test out the dash from the other TB while it was out?
budwich
2,045
kanata
the next place to check would be the schematic to see how the "working" and "non-working" circuits are energized.... go from there. Quite likely since the unit works in another truck, your truck has a broken power wire.... possibly at a common splice.
ScannerHeath
