NEED HELP Cluster/ECU TestBench AIO
GeeOhhX
3
CA
i was wondering if anyone could help me out or point me in the right direction of making an AIO test bench to connect my hp tuner and still have the option to fix clusters in one small bench. These photos were found in other posts to all their own credit.
7,714
Welcome to GMT Nation...
Most of what you will want to know for creating an "All In One" (AIO) Test Harness is thoroughly documented in the linked Threads below. You'll just need a little patience to pick out the sections that pertain to your LS Platform Engine ...look for "The Sloppy Mechanic" references along the texts and Copy Paste the Harness Pin-Out-Layout suitable for your LS Motor P01-P59 ECMs.
Also...visit the HP-Tuners Thread over and just below the Tech 2 Area from the GMTN Main Page and watch the Videos linked there for the "Real World Set Up" and check back in on your own thread here from time to time with any questions you want to discuss. It is pretty much all there... and again... it will just require some patience on your part to read through it all.
Start HERE:
...then visit HERE:
Please ...Don't request for any "Custom Engine - PCM - HP Tuners Test Harness Builds", etc. The whole point of my Documenting as many of the intimate aspects and details of Creating these Unique Test Harnesses... was to encourage OTHERS to make their OWN. I'm sure you understand.
Reactions: GeeOhhX
chirobo1
