The Climate Control stopped working on the Passenger Side and 'Rear Vents' of my 2002 Oldsmobile Bravada.
INITIAL ASSESSMENT:
• I researched the problem and arrived at the conclusion that it must be the ‘Blend Door Actuator’.
• I removed the ‘Blend Door Actuator’. Yes, it was a terrible experience.
• I manually moved the ‘Blend Door’ by spinning the axle to try and get hot air blowing, but it still only blows cold air.
FURTHER TESTING:
I have further tested the issue by performing the following actions:
• I manually moved the ‘Blend Door’ by spinning the axle through it’s full range. I checked out the range-of-motion that is keyed into the actuator itself. I then rotated the blend door and verified that it is going through the full range.
• When manually rotating the ‘Blend Door Axle’ counter-clockwise (from the fully stopped position), it moves with normal resistance until the last 1/3 to 1/4. After this point, it then feels a bit loose, but it still hits the stop limit and stops the rotation.
QUESTIONS:
1. Could the issue still be the ‘Blend Door’, even though I am hitting the stop limits on both sides?
2. Is there something else that I am missing? Perhaps a system controller, causing the 'Climate Control System' to blow only cold air through the Passenger and 'Rear Vents' of the vehicle?
3. Does anyone know what ‘Fully Rotated Axle Positions’ do, in the fully rotated CW and CCW positions? I would like to know the position it should be in to allow only heat.
IMPORTANT NOTE:
I noticed the problem about a month ago. I thought it resolved itself a week later, when the weather improved. I may be wrong on this, since I don't ever sit on the Passenger Side of the vehicle. If it did resolve itself temporarily, what could the issue be?
This may be irrelevant, since I can not 100% confirm that it did start working, but I am fairly sure it did.
INITIAL ASSESSMENT:
FURTHER TESTING:
QUESTIONS:
IMPORTANT NOTE:
