- Aug 24, 2014
- 189
Hey everyone. Well seems I keep having issues with return lines on the driver side between the rack and cooler. This time, got yet another leak right at the cooler where the hose connects with a clamp. It is the Dorman model I replaced in 2013. Lately it has been the return line, either leaking near the rack or above the cooler where the metal is crimped to rubber hose or at the cooler. Last time it was worm gear clamps that dug into the hose and destroyed it, had it replaced with a Sunsong hose with permanently crimped fittings. This time I have the factory style spring clamps at the cooler fitting. I am starting to wonder if the cooler fitting is scraped up and allowing the slow leak. I noticed also the newer Dorman coolers have a barb on the fittings which are longer. Did they redesign them or should I go back to OEM which appears easier to rust? I replaced mine originally as it was rotted. Thanks
Update: Which is better? I was leaning toward Dorman again but breaking my own rule of OEM unless aftermarket is better. I was concerned about OEM fin style cooler trapping salt and water in the fins like the last one that rotted. The Dorman is 6 years old and strong.
