Greetings all. New to this site from "that other place". After reading your comments on various notes on improved mpg by replacing an oxygen sensor around 80K miles, I decided to give it a try evan though I have no codes showing. I bought my 02 TB LT 2 months ago with 197K miles from original owner with meticulous maintenance records. It was getting ~ 18MPG on the highway which aint too bad. Records showed it still had the original sensor in it. I read in your threads the manifold sensor should be replaced about 80K miles. Per your direction I ordered the AC Delco Sensor and an oxygen sensor socket from Amazon.
I did the start engine for 20 seconds, wait 10 minutes, spray PB Blaster, wait 4 hours, thing. Using a 3/8 drive ratchet the original sensor came right off. The new sensor came with anti-seize on it. Screwed it in by hand, gave it another 1/8 turn nudge with ratchet to compress the compression washer like spark plugs have.
Filled gas tank and went for a 150 mile ride mostly on highway with some inclines. Filled it again at the same pump.
The old sensor had some differant color schemes on it as you rotate the tip but nothing that would cause a code to show.
Bottom line my milage went from 18MPG to 19.5MPG with a new sensor.
Thanks so much for the advice.
