So I changed the plugs, I put in the recommended 41-103 acdelco's, I also did an oil change
My problem is I had to ride around with misfiring plugs for about two weeks I also found out that I have been riding around with little oil for probably about that long as well
Well after all that it has a rough idle and when I come to an almost complete stop and when I lift off the break to accelerate there is a slight jerking, and my motor makes a slight blurp like noise until about 45 but you have to listen for it, after 45 it runs fine
Have I caused permanent damage to my motor, it had all these symptoms before I changed everything but they were worse
Go 10 miles off pavement, 70 miles from the nearest town with an auto parts store, and break a tie rod end and your spare is home safe in your workshop 250 miles away, or be 20 miles up a mountain and break your differential and have to pull yourself to a Motel 6 using your front wheels only and figure out how to get 850 miles back home while you're between jobs to change out the axle, or drive 1800 miles to Ellington, Missouri and lead a trail ride that ends up at dusk with 25 people in about 12 trucks lost in a national forest without a guaranteed shortest path back to civilization and dinner because there's not many restaurants open after dark in dueling banjo country and they're thinking about stringing YOU up to punish the arrogant Californian - now THAT'S a nightmare.
