Can't Find 2007 rear wiper blade replacement
DenaliHD66
I measured mine, I bought it as a 2007 arm and blade from the dealer a while back, and it is 13". I cannot find any 13" blades that would fit, all seem to indicate it is 12". Is there something I'm missing or is 12" what it actually is?
CaptainKD
31,990
Eastern NC
I have an '07 Envoy and my rear blade measures 13". I don't remember the brand but I think I got it from Walmart a while back.
DenaliHD66
Actually I am seeing 14" and 16" are what fit. 07 style seems to be 14 and older is 16". I have the 07 style now though.
Denali n DOO
5,596
I thought I read that the 07 rear arm only uses an oem GM blade?
DenaliHD66
Scott_mcd said:
I have a 16" Rain-X blade on the back of my 07.
It works without contacting with the side and top plastic pieces around the liftglass?
Scott_mcd
88
Yeah, here is a pick of the dirt on my back glass. You can see where the blade contacts the glass.
DenaliHD66
The top trim on yours looks much higher up than mine. There is a much larger gap between the 3rd brake light and where the glass starts on mine.
Scott_mcd
88
Ok, I didn't know there was a difference between the TB and Denali back windows.
DenaliHD66
Well I don't know about the Denali vs the rest, but XL seems to have different dimensions and short wheel base.
Jkust
I've heard the 07 on up is hard to come by as well. I need one for the 9-7 soon.
DenaliHD66
TBH I barely ever use it. I might use it to brush the occasional snow off while driving in the winter but I don't drive around with it on until I need to backup and use it.
DenaliHD66
Ok so I finally got around to replacing mine with the one I bought from amazon and......... it doesn't fit. Its the right size but wrong fitting. There is only one method of fitment too. ANYONE know the replacement wiper blade for the '07+ style wiper? It is 14 inches.
Instrumental
268
I got my 07 rear blade at AutoZone. Guy knew exactly what I needed, looks just like the OEM.
Yasha
