Cannot put more than 5 gallons in my tank.
GeoGoGo
166
Upstate NY
Hi Everyone!
I have an issue with my 2007 LT 4x4. I cannot but more than 5 gallons in my tank. I have a check engine and a code P0442. I know the cannister is shot and full of fuel or a check valve is bad. The earliest I can get an appointment at the shop is next week.
My question is there any work around for this until then? I am a traveling technician and it is a huge pain in the ass to have to put gas in 3 times a day.
Is there a hose that I can disconnect that will let the pressure out so I can fill it or at least put more than 5 gallons at a time? Thank you all in advance for the time!
Respectfully,
George D.
You could disconnect the vent hose from the tank to the canister. I wouldn't fill it though in case there's an issue with your filler valve/overflow/rollover valve.
Two reasons the canister would be full of fuel. Either you've been topping off the tank and overfilling it or the filler overflow valve is broken. I have experienced the latter and it would also puke gas out the filler when filled. That would require the tank to be replaced.
The P0442 could simply be a bad gas gap. You will likely get another code (large evap leak) with that hose disconnected.
Reactions: azswiss and Matt
timmerk
