Bun warmers problem
BINGA
238
So I've been dealing with this problem since i've owned the vehicle and figured I'd ask and see if anyone's had the same problem and might be able to offer a solution. My passenger side seat heater works fine and heats both the back and the seat, but my drivers' side only heats the back. Not super concerned right now seeing as its mid-june, but i'm on a project tackling streak and figured why not. Anybody had this issue and found the solution?
Seat heated grid pads that get sat upon a lot can crack and break. There are aftermarket replacements. I don't think anybody has posted about it here, but searching trailvoy would be fruitful, I know.
Denali n DOO
5,596
I guess your buttons are like mine? One for the seat and seat back, and one for the seat back only. You are pressing the correct button right? I only ask because my wife always thought the seat back only button was the power and the other button controlled the heat setting. I notice my passengers usually think the same thing. Maybe the heating element is unplugged or broken?
BINGA
238
:biggrin: Only fair to start with the most obvious of solutions, as those are the ones overlooked most often. I can dig it. Yeah, i'm using the button for both. I suppose the only way to know for sure if the element is broken is to take out the seat, dismantle it, and inspect it right? Hmm...not sure if I feel like tackling that one until the temperature drops again. Although...i have been intrigued by vehicles with both heated AND ventilated seats...wonder how that project would rate on the difficulty scale... :undecided:
Did you actually steer me to the OS? :eek: Just playin', i know there's still a wealth of knowledge there (if you can circumnavigate all the ads), if you got a minute, would you take a look at this and tell me what you think the cause may be? View attachment 21433
I noticed it when i went in for the TB cleaning. While at it, replaced all plugs, and all were fine...
Was there a lot of oil in that plug well?
It looks like you may need new rocker cover gaskets.
MAY03LT
Delmarva
Another way would be to unplug the element and, using a DMM, do a continuity test through it. I don't think I've tackled one in a 360 yet, but in nearly every other vehicle I can do it without removing the seat.
My passenger side seat heater (seat portion) wasn't working and of course the BOSS thinks this is the best option on the vehicle. I ordered two (one for when the drivers seat goes) from one of the GM parts places in the States for about 50.00 each. Took the seat out and dismantled the seat (you will need hog rings and pliers) replaced the pad and buttoned her up. No more complaints from Headquarters but of course it is summer.
A common problem is the wire burns out where it goes over the crevasses in the seats. Once it is burned the only thing you can do is replace.
here is the "How to on TV" New "How to fix the seat heater" thread. - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
here is the part # [FONT=&amp]89042164[/FONT] I think but these seem to be a lot more than I paid. You can search around but you will need a new heater.
Try this site GMC Parts - GM Parts - Genuine Replacement GM Parts - New GM Parts
Hope this helps.
BINGA
238
To my surprise, no. All looked in order and just like the other cylinders. No fouling, carbon deposits, nothing of note on any of the plugs. I wondered if the gasket surrounding the coil pack was damaged or unseated and not causing a good seal, but I even got the "suction sound" when removing the coil. :banghead:
BINGA
238
Hope this helps.
That helped a lot! Man is it nice not only when someone else has the EXACT same problem, but also has done all the hard work of making a step by step tutorial for the next victim. That guys thread was incredibly detailed, I'm surprised that wasn't made into an Article. Thanks for posting that link for me, there goes another weekend project...sheesh, do they ever end??? :undecided:
Oh, and P.S. "the Warden's" seat heater on her side works just fine :biggrin:
BINGA said:
Did you actually steer me to the OS? :eek: Just playin', i know there's still a wealth of knowledge there (if you can circumnavigate all the ads),...
Since many of us HERE wrote the good stuff over THERE, and we haven't spent the time to copy it here, I often run searches there. Using Google with "site:trailvoy.com" at the end of the search phrase is a very useful trick.
If they shut trailvoy down without notice it would be a huge loss, but their greed won't allow them to do that when they continue to sucker noobs in due to the high search ranking that a million posts give them. Too bad there's nobody comptetent left there to be caretakers for the dusty archives.
ready67
