I have a 2006 Buick V8 AWD, so no switches. If I turn into a parking space or other slow tight turning, it hops around on the front wheels, and mileage is bad.
I have had the front wheels off the ground and the front drive shaft is locked to the transfer case but front diff is quiet and smooth (no spline disconnect)
Also lifted just the rear wheels and idled the rear wheels so that they were both spinning and while it wanted to creep forward, it did not activate the 4WD lights on dash. The rear wheels may not have been spinning fast enough. While driving, I have broken one wheel free and the traction control light came on while driving but no snow here, so difficult to break both rear wheels free.
No lights on dash are activated and dealer says no codes. They wanted to change the Transfer case fluid which is now the second time in 78000 miles.
Should the dealer be able to tell if the TCCM is sick ?
Should the Dealer be able to tell if the actuator is lazy or stuck?
Trying to determine if I should go elsewhere or if it's just hard to diagnose.
I suspect the clutches are partially engaged and this will lead to a failure soon.
Any comments appreciated, but this is and AWD, not and Envoy or TB.
