So.... I'm back. In the last 2 months I have replaced the water pump , Fan clutch , Power steering lines , idler pulley , and ball joints. I did also chaged the DIF & Transfer case fluid but that's just routine maintenance . Anyway..... Ive had alot of help from you guys and I clearly couldn't have done it without you so Thanks! So I have a cracked intake bolt. its the second row from the front on the bottom (I will post a Picture). Im getting rather exhausted from the back to back issues I have had. What are my options on fixing this and how much damage is it getting from being used? I know the idea of it creating a vacuum leak and what not. Just needs some help again. Thanks
