Bose System C D wont eject
Hawge
18
I've got 2 cd's that wont eject when button is pushed , it says ... No Discs . Any ideas?
Black LT
Some people took the deck apart to retrieve them.
A few got lucky and pulled the radio fuse for a few minutes - replaced it - and the radio 'reset' itself. Worth a shot before disassembly.
Hawge
18
Thanks I'll give it a shot. Looks like APITA to get it out otherwise.
neohio
85
Does your head unit load all the cd's into itself?
Or is it a separate unit like an escalade has?
If your head unit loads all the CD's in the dash, then you do not need to remove the center console to remove the radio.
Hit up metra online, or scosche. Both are vendors that sell vehicle adapters for aftermarket radios.
If you plug in your truck data, they will spit out what kit to use, then simply download the instruction manual from the kit listed and follow the step by step instructions to remove your head unit. Installation is pretty much reverse of removal.
Edit,
Download the PDF from http://www.metraonline.com/files/products/INST-2009_web.pdf
Go to page 14 for Envoy instructions.
Go to page 13 for Trailblazer instructions.
ljoh.sl6
