Bluetooth static
Me007gold
1,106
After I installed my radio, I tried out the bluetooth, and while I dont have any static on my end, the people I talk to say they have lots of static and echo. How do i eliminate the static? I know there will be some echo because the mic will pick up on the speaker. I have the microphone mounted on the overhead console and the wire is running down the A Piller
RayVoy
939
Ok, just to understand, you have installed a non oem radio with bluetooth.
And, it requires an external mic to pickup your voice, you hear the "called/calling" party through the vehicle speakers.
And, you are using your handheld cellphone.
blazinlow89
2,088
Mine is mounted the same way, never issues with static. Might be picking up interference along the cable. Check to see if it crosses with any power wires.
Me007gold
1,106
I have it running down the a-pillar and under the dash, I am wondering if I run it on top of the dash and down the same hole that the light sensor is will make a difference.
Try un-pairing and pairing it again. I have heard that putting the phone farther away from the Bluetooth device during the pairing helps because it will use a stronger channel due to the distance. Check for a firmware update for your phone.
DDonnie
2,631
Depending on the HU, there could also be a firmware update for that too.
ghenny440
368
I have my pioneer installed the same way, and it was in josuelt's old truck he never used it cuz of static and echo, like yours, come to find out the zip tie that was holding the unit to a bracket under the dash had popped the mic out a bit once installed in my truck no more problems
ghenny440
368
If its a pioneer, in the system menu while in bt mode there is a feature that allows you to cancel echoes
timmerk
