Beware "The Glitz" and Get "The TRUE Specs"
8,573
If you accidentally wind up *Clicking* on THIS Impressive Looking Site in search of Accurate Information on the GMT360 Platform, Beware the surprising number of Out and Out Inaccuracies ...especially concerning Engine Component R&R Torque Values and Repair or Rebuilding Procedures:
"Shine THIS One ...On...." -=mrrsm=-
Incorrect is right. Just looking at their description of the timing system, it incorrectly says this:
On the Chevy 4.2 engine there is a rear timing chain that runs the engines balancer shafts which mitigate the engines vibrations.The balancer shafts run off of a timing chain that also connects to the rear end of the crankshaft. In order to change this timing chain youwill need to remove the transmission from the engine and then remove the rear timing chain cover.
Whatever system they used to aggregate the info incorrectly used info from the 5 and 4 cyl variants of the Atlas. What garbage!
Whois info is kinda strange. It was first registered in 2022 and says it's for sale :blinkhuh:
Turning off my ad blocker, I only get an adchoice ad to download the specs. Some of the other brands linked have similar pages, some others are invalid. Probably some sort of money making scheme.
8,573
Verisimilitude ...Made possible by... Your Friendly Neighborhood AI...
  • Sad
RRiggins
