Berryman's Soak number two. Thinking about adding some aeration?
c good
531
Thinking of adding some agitation of the Berryman's in the oil pan. I have some small tubing that will go down the dip stick tube. Run some low flow air down it to create some agitation of the Berryman's. I'm thinking it might help with removing the particles from the pick up screen. What does the GMT Nation brain trust think about this as an option? Thx...
Ilikemy3s
369
would that cause some of the Berryman's to be sprayed onto parts of motor that it should not be ?
c good
531
That's also what I was thinking, that's why I was thinking some low volume low pressure air. In the meantime I've drained the soak, am going out on a drive with some cheap oil and filter....then back for another oil change. Hopefully it will solve my low oil pressure like it did last year.
4,656
I did a few Berrymans treatments over a week, about 2-3 soakings.
I followed that up with some BG44K and that stuff really cleans things up.
I would treat the fuel tank to a couple cans before I ran B12 through it....I don't think that's good for the seals.
Firebaugh86
