Something else to let you guys know, with the mechman alts, they have the smaller diameter pulley (1.75") and from what I learned from them, if you get the engine to rev up high like into 6k rpm, you will have the alt shut off. Now I don't know if that was a command from the PCM to shut it off like how it commands the alt to stay off on cold startups. I talked to Matt at mechman and he said that I really overspun the alt. I had it at 27k rpm for the alternator and they rate them at a max of 18k rpm. I almost never get the engine up in that RPM range but the one day I hammered on the gas to get on the thruway and it got up to 6k rpm and the alt stopped charging for that moment. So for the other users out there, be warned from my issue I learned from and keep your RPM's limited to 4400 engine RPM's. Anything above that and you are exceeding the alternator spin rate they rate them at and are at risk of breaking the bearings and other components from high speed. You could easily correct this with a larger pulley than the 1.75" one they come with, they recommended I use a 2.5" pulley but the issue with that is the output at the lower RPM range would absolutely suck. I opted to keep the 1.75" pulley on the alt and carefully monitor my rpm's when accelerating to prevent it from getting above 4400 RPM engine speed.
